I mentioned this in the topic referencing a related issue in v1.4.7, but it may be overlooked because of that. I’ve loaded v1.4.8, and now MM gets stuck trying to autoload the Stellare plugins. I removed both to test if all others loaded OK and they do, then I added them back to the SD card and tried to manually load them and got “Error loading plugin: Error: no plugin .so file found. Plugin corrupted?”. Just to double-check I re-downloaded the plugins and put the fresh copies on the card, same message. These are the only 2 that have not been updated from the original 1.0 SDK, may not be a factor but thought it worth mentioning.
I’m stuck on Auto-loading Stellare Modular Creative…
MM never gets past this. I had to remove them for 1.4.8 to finish loading modules.
Same issue here. Suggestions?
I removed the stellare modules for now.
Thanks for the report. I can confirm, I broke something with the untarring of plugins in v1.4.7 and apparently didn’t fix it 100% in v1.4.8.
I’ll push a fix when I solve it.
Ok, fixed in v1.4.9!
Sorry everyone… I will be better about testing all plugins before making a release!
Great! Thanks Dan for fixing this fast.
