Midi parameter dump on startup not working correctly for some channels
I currently have the MM setup with H4Midi which I have plugged into an x-control touch and an oxi e16. I have it mapped so that each page on the e16 uses the same cc’s but on a different channel. I have midi feedback on. I can verify from a computer that this setup is fully working when sending midi to the controllers, and when changing parameters on the MM I see them reflected properly on the controllers too. However when I start up the MM the midi info gets dumped out to the devices, and i can see in my midi monitor (I set the H4Midi to also output over normal midi so I can capture it on my computer) that I get the midi information for channels 1, 5, 6 & 7. For some reason I get nothing for 2, 3, 4 even though they are mapped in the MM.
If i then change a value of a parameter on one of these channels it is correctly reflected on the hardware, so it’s only during the startup process that this is failing. I’m not sure why this is the case but since there is no manual option to dump all the values again it’s a bit of an annoyance currently
Dump of startup midi out attached.
mmstartupdump.txt (4.6 KB)
I dug into this a bit and it seems like it’s because I have too many midi mappings, when it starts up and walks all of my 234 mappings it ends up overwriting the earliest ones because the buffer is CircularBufferOpt<MidiMessage, 128>
Sorry, I missed this, I know it’s a few weeks old now. That sounds about right, the buffer only holds 128 messages, so 234 mappings could overrun it.
I think we can increase that to 512 messages in the buffer, there’s plenty of memory available.
no worries. I made a build where I increased it to 512 and it’s working fine so it’d be brilliant to get that into the main build
@danngreen any chance of this getting into the next release? I’m stuck on my current custom firmware build atm so I don’t need to patch it every time
Yes! I can put this in. Appreciate the bump!
@danngreen did this make it into the new firmware release?
Yes, sorry, it got buried in the release notes. I bumped it up to 512
Awesome. Thank you very much
