I’m not sure if this is a bug or should be a feature request. The meta-module does not connect to any midi hubs, Which means if you have multiple controllers or devices, You cannot connect those to the meta-module through your midi router/hub.
Meta-module does not connect to MRCC or MioXL midi hubs. It appears meta-module wants to be the host and so it will not connect to a host.
