in vcv, i’m trying to get keyboard shortcuts to trigger the wifi and or save buttons to help speed things up. often times when working on a patch, the wifi/save buttons are off screen or at different spots on the screen. so it can be a pain to have to locate them and mouse over to them each and every time.
ive tried using the stoermelder ‘stroke’ module in tandem with the umap module- mapped to either button. but this isn’t working(also played with different offset setting -10<>+10 or 0+10). the buttons on the mm module in vcv just don’t respond. i also tried mapping a button on my midi controller to the mm wifi/save buttons using the fundamental midi map module. i can see the save button depressing on/off ui states, but nothing is happening, no explorer window opens. perhaps i am just setting things up wrong here. or perhaps there’s a bug?
