Meta module as a visual synthesizer
I’ve been playing around with some of the visual plugins on the MM, jw trees and flower patch mostly, and it has been very fun. I was wondering if there’s a way to “extract” the graphics to either project them on a screen or process them with other gear, is it possible? Would a hdmi or composite expander be too crazy or niche?
That would be amazing if the meta module could do some video synthesis.
if you found the right cam, it could look really interesting to send the mm screen through resolume/efffects or touch designer, cv outs from the metamodule also changing effects inside the video app
but as it is now, there’s no way to send video direct out via the usbc port.
