Merge and Split Modules
Is there any work being done on porting the fundamentals merge and split modules. I’d really like to be able to build the diatonic sequencer from Jakub Ciupinski excellent youtube video.
Agreed that it’s a fantastic use of stock fundamental modules but think it won’t work until 4ms Meta handles polyphonic signals. There’s also the question how computationally intensive each Fundamental Quantiser is and whether stacking a large number will overload the Meta.
I have it working (kinda), just didn’t use the merge and used the count modula switches instead and I had to remove the plateau. Now I just got to map my MIDIMIX.
Excellent. the air windows Galactic uses less cpu and sounds pretty good. If you’re just processing cv, you can try switching the 4ms to the lower sample rate of 32K or less.
Completely forgot about that setting
