I’ve been enjoying using MM to generate some nice sounds - thanks for all the work!
One note though - When I save a patch from VCV for the MM using Marbles (Audible Instruments) I find that the Clock Range and Pitch Range choice resets to x4 and +/- 5V setting in MM. When I tweak the patch in MM everything works as expected.
Could be related to the “defaults” issue mentioned here: Marbles : steps param reversed - #5 by TheTechnobear
              OK, I see what the issue is… thanks for the report
              Hey guys,
First, thanks @danngreen & the 4ms crew for such an amazing game-changing module ! Had the chance to demo it with you Dan in Berlin at SB and it’s beyond expectations, kudos
This issue is still not fixed right ? Wanted to add that the T & X modes are also not saved and have to be changed from the MetaModule itself every time we open a patch created in VCV.
Hopefully we could get a fully working Marbles soon - such an important piece of the MetaModule ecosystem, a core building-block for generative (and Mutable) lovers like me
Lemme know how I can help !
Thanks again, cheers
Romain
              I fixed it a while back but got side tracked and never merged it in! Merging now, it’ll be in the v1.6.2 release
              Hey @danngreen,
Updated my MM to 1.6.2, tested and happy to confirm it’s now fixed  Awesome !
 Awesome !
