Slightly cryptic topic description but should be easy enough to understand.
(This occurs with voxglitch sampler x8 and sickozell drum samplers, but might affect others of course)
If I try to load a sample in slot 1 it won’t open up the browser to load anything.
If I load a sample in slot 2 it works fine but is actually the sample for slot 1.
A sample in slot 3 is actually the sample for slot 2, etc.
Not a biggie but definitely odd imo.
yeah i had this bug alot on different modules
Just a bump on this to try an get it noticed…
Some other negative effects of this bug:
Slot 8 of the Sampler x8 cannot be accessed at all
Trying to change a sample in an existing slot doesn’t work
It’s a shame because there aren’t many plugins that can play multiple samples which are obviously very useful for sampled drum kits etc. It makes these valuable features much less useful.
Any updates for this would be very much appreciated. Cheers.
I’m still seeing this in Voxglitch Grain Engine Mk2. Plus the sample seems to wrap around so that a tiny bit of the sample end is played at the beginning. I sent a bug report to Voxglitch. Is this a MM issues?
