"Load Patch" shows different files on sd card as notebook
Hi, I’m using firmware 1.6.7. When I move the sdcard from my notebook to the MetaModule I see different yml files then I prepared in the notebook. For me it seems that I see an old status of the sdcard. My files are in directorys on top level. Any idea?
Thanks
Keep in mind that the MetaModule displays the patch name, not the file name in the list.
So if you are renaming patch files using your computer, then the MetaModule will display them differently. The patch name is on the second line of the patch .yml file, in case you want to open it up in a text editor and check.
If you still think there’s an issue, try doing a simple test: format the SD card so it’s clean. Then copy one patch file to it. See if it shows up on the MetaModule. Go back and copy another file. See if that shows up. Repeat…
The MetaModule is just reading the file system from the SD Card, so it has no access to previous states of the card. It could be that your OS is not syncing the card before ejecting (e.g. always use your OS’s “Eject” or “Unmount” command before physically removing the card).
Thanks, that info helps me.
