So some modules (the VCV quantizer for instance) have presets internally. There is a module called “Preset” I believe that you link to whatever module you want and it gives you cv control of selecting the presets or a knob. Do we have that module or anything like it?
One way to use presets is to use the Bogaudio PGMR, which is designed for this. and have them output to the CV inputs you want. you can stack multiple PGMRs on top of each other for more than 4 steps, or more than 4 presets to save. I am not yet aware of a “control knobs without a cable” method on Meta like the Stoermelder module sets Transit, 8Face, etc. But they would be a delight to have eventually.
I’m sorry, maybe I wasn’t very clear. It happens. Then you right click on the QNT module from VCV, you have a “Preset” menu, with all of the scales in that “Preset” Menu. I believe there is a small module that allows you to address the “Preset” menu of other modules with cv/trigger etc.
@danngreen We need a module like this brother, can you get one of these developers to release something like this? Not sure if there’s others but this would be fantastic on MANY levels
