Is there a Polyphonic VCO on the order of Knobula Monumatic eurorack module?
Would love to find a really versatile VCO with 6-8 voice polyphony that will run in MM. Thanks for any suggestions!
Greg
I see the Plaits clone and Bogaudio FMOP as options so far.
O, and if I do get this going, can I run it in the MM polyphonically using TRS Midi?
Most of the VCOs support polyphony in the -poly beta firmware. You can test them in VCV — if they work polyphonically in VCV they’ll work on the new firmware.
The firmware only supports four-channel polyphony at this point so you won’t get 6 voices.
You can control them with MIDI via USB. TRS MIDI is coming in the MetaDig expander, which is not yet available. 4ms Company MetaDig - Eurorack Module on ModularGrid
Really appreciate the info on this!
Per this post from Dan from last month it may be that the next module is MIDI focused but not the MetaDig:
