We’re back on the Nostromo. Dan confirmed that MIX8 uses 58% of the CPU when all jacks are patched, so that’s been replaced with 2x VCA Mix (no panning, though), and Ensemble Oscillator, Noise Plethora and Plateau are back in. CPU usage: 90% (still at 24 kHz, regrettably
). Just add xenomorph blood and stir gently.
Update: The issue with Noise Plethora freezing MM has been fixed in the latest beta. Dan helpfully pointed out that MM only accepts single inputs to jacks, so a STMIX has been added.
INT USCSS Nostromo.vcv (4.6 KB)
INT USCSS Nostromo.yml (17.1 KB)
