One of my favorite parts of VCV is Instruo stuff, curious even if it’s some of the more basic modules if there are any plans for this? Is this something that could be ported personally or would it require further permission?
I’m a bit new here, sorry if this has been asked before!
Mike
The Pressed Duck stereo mixer from CV Funk has tanh saturation in its level control.
It’s a full on mixer with some extra bells and whistles, so it’s gonna eat more CPU than a simple tanh module, but might fit some of your intended use cases.
I’m working on reducing the CPU load of PressedDuck for MM, in a future update.
Also, the Node module has the same tanh saturator built-in to each channel (just turn the Gain up to 20X). It has a lot lower CPU footprint than PressedDuck since it’s only 2 channels. It’s not yet available on MM, but will be soon!
My tanh saturator is similar to the Instruo one, but it’s more symmetrical. To achieve a more similar effect to Instruo you can to offset the input signal by about -0.1V.
