HetrickCV Phasor Generator frequency too fast
The HetrickCV Phasor Generator module when running on my MetaModule (firmware v1.1.1) appears to be generating a phasor at audio rate frequency even if the “Speed Range” is set to Slow. If I set it “Fast”, the frequency speeds up even faster. It happens with or without an external Clock or V/Oct signal patched in.
I dont think I can share the .vcv patch file here, but here is a screenshot - its super simple. The scope shows a comparison of the vcvrack phasor vs the Eurorack MetaModule output returned through my ES9 interface:
Here’s the contents of my simple-as-possible yml file:
PatchData:
  patch_name: PhasorTest
  description: Hetrick Phasor Test
  module_slugs:
    0: '4msCompany:HubMedium'
    1: 'hetrickcv:PhasorGen'
    2: 'hetrickcv:PhasorRanger'
  int_cables:
    - out:
        module_id: 1
        jack_id: 0
      ins:
        - module_id: 2
          jack_id: 0
      color: 35419
  mapped_ins: []
  mapped_outs:
    - panel_jack_id: 0
      out:
        module_id: 2
        jack_id: 2
  static_knobs:
    - module_id: 1
      param_id: 0
      value: 0.5
    - module_id: 1
      param_id: 1
      value: 0.5
    - module_id: 1
      param_id: 2
      value: 0.5
    - module_id: 1
      param_id: 3
      value: 1
    - module_id: 1
      param_id: 4
      value: 0.5
    - module_id: 1
      param_id: 5
      value: 1
    - module_id: 1
      param_id: 6
      value: 0
    - module_id: 1
      param_id: 7
      value: 1
    - module_id: 1
      param_id: 8
      value: 0
    - module_id: 1
      param_id: 9
      value: 1
    - module_id: 1
      param_id: 10
      value: 0
  mapped_knobs:
    - name: Shaper 1
      set: []
    - name: ''
      set: []
    - name: ''
      set: []
    - name: 'Shaper 1 Seq 1-6'
      set: []
    - name: ''
      set: []
    - name: ''
      set: []
    - name: ''
      set: []
    - name: ''
      set: []
  midi_maps:
    set: []
  midi_poly_num: 0
  vcvModuleStates: []
Heres the module output in a scope, showing that when Speed = “Slow” and Frequency = 0%, the Phasor is cycling at 200Hz (5 ms per cycle).
MM firmware v1.1.2
Sorry, I missed this message from weeks ago!
I can verify this in firmware v1.3.1 and earlier.
Here’s a v1.4.0 beta version which fixes it:
https://github.com/4ms/metamodule/releases/download/firmware-v1.4.0-beta-1/metamodule-firmware-v1.4.0-beta-1-firmware-assets.zip
Thanks very much, just tried the 1.4.0 beta firmware, and it now works.
@omricohen has this video on the Hetrick Phasor modules: https://www.youtube.com/watch?v=aFQhhO0ku14, also an epic 90 minute in-depth walkthrough on his Patreon. Will now be re-watching these shortly. :slight_smile:
really glad you mention this video! been curious what all these hetrick phasor modules could be useful for
Yeah! One other synergy is using the Phasor modules with 4ms’s own phase-based Catalyst Sequencer. That way you can use the MM for generating and shaping phasors, and the Catalyst to convert it into sequences.
