running the latest firmware… I’m often seeing the meta module completely freeze while using the built in MIDI → CV…
in this specific case, the midi device is an h4 midi wc with an OP XY connected on the other side (as the meta module / OP XY don’t seem to want to connect directly)
are others having issues?
