I really like the look of Vostok Instruments’ new Halo module: four LFOs with logic outputs, an easy way to get a bunch of related modulation CV at varying degrees of craziness.
I don’t know what the latest is on the Vostok MetaModule ports but in the meantime I made a patch that turns your Meta into half a Halo: two LFOs with square and triangle outputs plus analogue AND / OR / XOR / SUM. If you have the Buttons or Jacks expanders you could make this cooler.
Half of Halo.yml (8.7 KB)
Halo.vcv (2.6 KB)
