Granular scrambler
Here’s the Granular/IDM patch we posted on social media a few weeks ago:
Granular synthesis patch with MetaModule!
External audio path:
-Audio out 1 & 2 is main output
Internal audio path:
-Kick, Snare, + hi hat go to 3 channels of the main mixer
-A macro oscillator running the wavetable algorithm is processed through a texture synthesizer and then goes to the main mixer.
-The mixer goes through a master reverb and master limiter.
-White noise runs into the input of an analog shift register
Internal logic path:
-Main clock generated by the SEQ 3 and divided by the rotating clock divider
-The RCD outputs are clocking the Shuffling Clock Multiplier and analog shift register’s clock inputs.
-The shuffling clock multiplier uses an external switch to toggle between two divisions.
-Outputs from the SCM trigger the main amplitude envelope for the macro oscillator and the freeze logic input on the texture synthesizer
The analog shift register is our master modulation source and controls:
-Wavetable timbre
-Wavetable color
-Grain position
-Grain size
-Granulation dry/wet
-Reverb dry/wet
-Reverb decay
-Reverb diffusion filter high band
-SCM Rotate
-SCM PW (freeze length)
Metamodule knob mappings:
A - SCM Rotate
B - SCM Slip
C - SCM Shuffle
D - SCM Skip
E - SCM PW
F - SCM Division selection
U - Main warping sound volume
V - Kick volume
W - Snare volume
X - Hi hat volume
Y - Decay time for main warping sound
Granular.vcv (4.2 KB)
Granular.yml (18.2 KB)
The files for this post have been updated to run with our new firmware so that they automatically load at the recommended sample rate and block size of 32khz/512. Enjoy :D!
