Good switches for MM?
I’m looking to make a switch patch for MM. What good sequential switches and other switches that will work with MM would be a good place to start. I really like the hardware Noise Engineering Vice Virga and Doepfer A-150-8 Octal and Joranalogue Switch 4.
Thanks!
Greg
-Fundamental 4>1 & 1>4
-Count modula 1-16, 16-1, 1-8, 8-1
-Bog Audio 1-8, 8,1
More advanced “switching”:
-Count modula carousel (rotation switching)
-Count modula Multiplexer (multiplexes 1 signal to 8 outputs with a send/return loop for each stage)
-Hetrick CV scanner which is an 8 > 8 multiplexer that also gives you smooth interpolation between steps for smooth switching (really an 8 slot crossfader, very cool).
so appreciate this!
How about shift registers that you respect that can run in MM? Might as well see if I can make a multi purposed patch for both!
I really like the Count Modula shift registers as well :slight_smile:
Great!! Thanks!
