Getting block size from within plugins
What’s the correct way to get the block size which has been set from within a MM module? Is there a block size change event? Thanks!
No, not yet. I think I’ll add a global function for getting the context.
Safe to assume minimum block size is 16 for now.
That would be great to have in future. The RNBO bare metal engine works in blocks and I think it might make sense to keep that in sync with the MM setting
I’m address this in api-v2.1: Feedback on SDK v2.1
