GenTweak Self Generating Patch. 4 banks of knobs that do various things both to the melody and the sound. Unfortunately it wont run 48K/64, but will work in 32K/64 or 48K/256 using V1.41b. Be careful with 2 QUANT knobs as they can ‘break’ the generations. I’ve attached 4 variants for taste. Enjoy what can be squeezed out of 26Hp.
GenTweak.yml (52.2 KB)
GenTweak.vcv (6.2 KB)
GenTweak2.yml (52.0 KB)
GenTweak3.yml (52.0 KB)
GenTweak4.yml (52.1 KB)
I’ve set the audio out, but I’m not getting any sound from GenTweak.vcv. There don’t seem to be any CV or trigger outputs going to Plaits.
Have you tried the other 3 versions ? They were saved directly from the 4msMM onto the SD card as running patches. The first version was the exported patch from vcv rack so it will need linking to the 4msMM audio out jacks.
i was able to get some sounds from the .vcv but needed to turn the Z knob (->bog 8:1 module->select knob) all the way up. also turning up the A C knobs created a lot of plucks
‘a lot of plucks’ sounds about right.
I didn’t spend time defining the optimal max/min sweet spots of each knob - users will need to use their ears to dial in what sounds good. FWIW I tried reloading the uploaded yml’s from my PC back onto the SD and they all playback instantly & properly on the 4ms. As previously mentioned I’m using V1.41b and the latest plugin’s from the 4ms site, so there maybe differences between peoples 4msMM setups.
