Generative patch with MetaModule
Here’s a patch we recently posted:
This is a 4 voice generative synth patch. There are 4 sine wave oscillators with their own dedicated envelope and VCA. Each voice has its own random voltage generator and quantizer with all 4 voices sharing the same scale. There’s controls for decay time, note offset, note random amount, volume, and pan for each voice. The master reverb dry/wet and decay are also mapped.
To use the patch, you need to feed gates or triggers into audio input 1-4.
External Audio path:
-Main audio outputs on channel 1 and 2
-Audio input 1-4 are gate inputs for channels 1-4
Logic mapping:
-External gates plugged into MM are sent to a random voltage generator and envelope trigger input for each voice
Internal Audio routing:
-4 sine wave VCOs have their own VCA and envelope
-Each voice goes to the master stereo mixer
-The stereo mixer then runs into a master reverb
MetaModule knob mapping:
Knob Set 1
A - Voice #1 note offset
B - Voice #1 random amount
C - Voice #2 note offset
D - Voice #2 random amount
E - Voice #3 note offset
F - Voice #3 random amount
U - Voice #4 offset
V - Voice #4 random amount
W - Voice #1 decay
X - Voice #2 decay
Y - Voice #3 decay
Z - Voice #4 decay
Knob Set 2
A - Ch. 1 Volume
B - Ch. 2 Volume
C - Ch. 3 Volume
D - Ch. 4 Volume
E - Reverb dry/wet
F - Reverb decay
U - Ch. 1 Pan
V - Ch. 2 Pan
W - Ch. 3 Pan
X - Ch. 4 Pan
Y - n/a
Z - n/a
Generative.vcv (4.3 KB)
Generative.yml (24.6 KB)
This patch has been updated to work with our newest firmware so that it automatically loads with the recommended sample rate and block size of 48khz/512. Enjoy! :smiley:
Hi, I just bought the Meta, so I downloaded your patch to try it out and thought it was fantastic; however, I don’t understand why the output volume is so low. How can I fix this?
Thanks.
Hey! Glad you like it. Try adding a SeventiesComp from ProducerPack and tweak until you like how it sounds.
