Just updated the Fundamental (VCV Free) plugin with the Wavetable VCO and LFO modules and the Delay module.
This requires firmware v2.0.0-dev-11.3 (will not work on v11.2 or earlier), because these modules use the filesystem and libsamplerate features of dev-11.3.
Can you import your own wavetables?!?!
I can confirm, you can! Just go down to the last item on the module for options and there’s a load wavetable option. Clutch!!
Man that’s killer! This is one of the main modules I’ve been waiting for I know it may sound silly, but I’m super stoked about this one. Do you just put your wave tables in a folder wherever you want you can navigate to it?
Yes, you can import them from any subfolder on your SD card. I just made one labelled Wavetables (how original).
Any idea how much CPU juice the new wavetable osc uses? Can you get 4 voice Poly out of it? ![]()
Easily. A patch with 4 of the WTVCO with the outputs of each one patched, runs 30% load (48kHz, 64 block).
I did the same it works perfect!
