I have problems running this patch in 2.1.1. It runs at 80% and causes the module to freeze some times. I already formated the sd card. Some times it runs fine and freeze happens in the first minutes or seconds. I seem no to have the rights to upload it here… Thanks for your help!
Thanks for your commitment to lift my account up=) Here is the patch. Its a instant rumble chain for kicks plus a DLD and a Orcas sequencer. Quite simple. I had problems with it chrashing or better freezing since I build it. I updated eveything, but still I get this freezing. Sometimes I hear a high freq noise, sometimes the patch plays on, but i cant navigate trought modules or menu.
kick_rumble_chain_orcas.yml (19.7 KB)
Soo… I rebuild the patch using different module and it seems to work. So there is a good chance, that there is a bug within the combination of the patch I posted…
Sorry I missed this post originally. Which modules did you replace to get it working?
I completely rebuild it based on simpler modules and I cut orcas, so I have no clue which one caused the freeze.
