[FIXED] New patches not loading
I received my Metamodule a few days ago. Internal patches load fine, but I’m having problems loading patches that I’ve created or downloaded from patchstorage. For example, if I try loading EnergyRingModOscwnotch, nothing appears on the display. A simple patch using 2 x Erica Wavetable VCO, VCV VCA Mix, 2 VCV Oct and 2 VCV ADSR EG also displays nothing, although if I press play, I get a message that Fundamental: Mixer and eight others are missing. The patch doesn’t use these, so I’m completely confused about what’s going on.
I tried using the default all VCV patch that’s created by VCV Rack and this didn’t load either, although it did display the message, “Fundamental: Mixer and 11 others are missing.”
the internal patches use the ‘built in plugins’. have you downloaded/installed all non built in plugins? those don’t automatically come factory installed.
here are the instructions for dealing with non built in plugins (highly recommend reading through the whole manual):
download plugins here:
https://metamodule.info/plugins
don’t forget to set the plugins to ‘autoload’ so you don’t have to reinstall them every time you boot up the mm.
also you mention “2 x Erica Wavetable VCO” - erica synths have not ported any of their modules over to metamodule format so those won’t work. hopefully they will be ported at some point tho!
Hi. Thanks for that info which is hugely helpful. I guess it pays to read the documentation!
Does anyone know what plugin the VCV VCA lives in? It’s seems like a generic “VCV” branded plugin.
That’ll be in the Fundamental plugin.
