[FIXED] Multimap problem
I just discovered this feature- I downloaded a patch with 3 knobs multi mapped.
I’m trying to add a 4th. In the knob set view, I see the orange line below the module. But I can’t scroll to the other mapping. When I go to the module view, I can see that the knob is assigned and working on both the modules it is set too. I just can’t switch between the 2 in knob set view.
Could I be missing a step?
Edit- maybe it doesn’t really matter, it does still control both modules, I guess being able to scroll between the assignments in knob set view is really just so you can see how it is set up, it doesn’t effect functionality
I just encountered that bug too! It’s a regression (it used to work in an earlier firmware version).
