[FIXED] EnOsc_step_seq patch - crashes module
I tried to load the EnOsc_step_seq patch (factory) , unaltered.
and my MM completely locks up, unresponsive. as soon as I hit run.
all other patches are fine (at least that Ive tried)
FW; 1.1.1
Same here. I’m on the latest FW as well, though I think it happened with earlier versions too.
I can confirm that this patch will not run at 96kHz sample rate due to CPU load, but you should see the “audio stopped because of patch load” warning onscreen. Does it work for you at lower sample rates?
I’m set at 48k/64 block. I have tried any lower settings, but I can later
Edited to add- this isn’t just a message that audio stopped because the load is too high. It locks up and the module needs to be restarted
Weird! The patch runs here at 48kHz with block size 64. There is only one input jack in use in this patch, so that doesn’t seem to be a factor in driving up the CPU load. Perhaps Dan will have some ideas on this one.
Default settings for me.
And it just hangs , no overload warning etc.
This was reported elsewhere and has been fixed on the main branch.
I’ll tag and release it in v1.1.2
Ok, fixed in v1.1.2!
https://metamodule.info/downloads
