[FIXED] DLD channel B problems
I’ve had this issue a few times, so figured I’d mention it. Sometimes, when I create a patch with the 4ms DLD, channel B just doesn’t work- feedback is up, delay feed is up, mix is up. Time knob has no effect. Doesn’t matter whether I’m using input/output sets A or B. Delay A always works, it’s just B that sometimes doesn’t.
I saved the patch with the broken DLD channel B to send it to 4ms, but upon restarting the meta module, the B channel started working again. So, it’s strange that sometimes it just works and other times it doesn’t.
Has anyone else experienced this?
Anyway, just figured I’d report it, as the DLD is one of my favourite modules and I use it in almost every patch.
Thanks.
I can confirm here.
Happened to me in the first patch I made with DLD. Not being familiar with DLD made me scratch my head. But on the second load it worked ok.
Ya, it seems to happen pretty frequently. I find with most of my patches chanel B doesn’t work. Hopefully there’s a simple firmware fix for it.
Ok, Yeah I’m seeing oddness on channel B also. Thanks for the report.
