Firmware v2.1.11
Announcing firmware v2.1.11, now adding some handy new features:
Download here
New Features:
Minor features
  • Add support for endless rotary encoders. (Impromptu plugin uses these). These can be mapped like any knob, but of course mapping a physical non-endless knob to a virtual endless encoder makes it not “endless” anymore. In the Adjust… pop-up you can use the encoder on the MM to endlessly adjust the virtual encoder.
  • Handle some widgets that have no graphic. The use-case for this was the pads on the Impromptu CV-Pad module. These essentially are invisible buttons. You can now map and select these like any ordinary button.
  • Draw most recently moved knob on top. Thanks to @hemmer. This adds support for stacked knobs, see Draw most recently moved knob on top by hemmer · Pull Request #559 · 4ms/metamodule · GitHub
Fixes
