Firmware v2.0.2
Announcing Firmware v2.0.2:
This adds four new built-in modules to the HetrickCV brand:
  • ClockToPhasor
  • Normals
  • PhasorToRandom
  • PolymetricPhasors
Thanks to @trickyflemming for these new modules
BTW, Normals was specifically designed for the MetaModule to help with patching with external synths. You can have a virtual module patched through the Normals to another virtual module, and then when you physically patch a cable into the MetaModule, it will break the virtual connection and use the physical signal instead. This is great for example, having an internal clock generator that you can override with an external clock just by physically patching the external clock to a jack on the MM panel.
What a great idea! Thanks @trickyflemming
Thank you! For people wondering how to use some of the new modules, @omricohen made an excellent video that includes Phasor->Random and Polymetric Phasors. I need to find a moment to update the documentation for those. I saw that the new 4ms x0x modules are out, so I’m checking those out tonight. Good luck with Superbooth and safe travels!
That’s awesome I have been absolutely loving the 2.0 meta so far it is amazing. Thanks for all the hard work updating the module.
Exactly what I was looking for to connect my sq-1 clock out without disrupting a patch!!
