Firmware-v2.0.0-rc1
This is the first release candidate for v2.0 firmware. It will run plugins compiled with the “dev-13” SDK and plugins compiled with the api-v2.0.0 SDK.
(I had previously stated I was considering dev-13 a release candidate, but logistically it’s easier to give it a distinct version suffix).
What’s changed since v2.0.0-dev-13.9
  • Allow setting MIDI channel for MIDI knob and jack mappings
    • You can now select the MIDI channel when creating or editing a MIDI mapping from within the MetaModule. Support for setting MIDI channels will be present in the next VCV plugin release (it’s already in the vcv plugin code if you want to compile yourself)
  • Fix MIDI connection repeatedly connecting/disconnecting after a physical disconnect
  • Allow up to 128 plugin files to be scanned (raised from 64)
