Pleased to release v2.0.0-dev-12.2, which adds MIDI Output support and a few other things:
Features:
Midi output via Rack interface
Ported CV->MIDI module to “RackCore” brand
Fixes
Fix jack being marked unpatched if panel jack is unplugged but internal cable remains
Fix GUI slowdown when lots of mapped knobs are on the screen
Fix AsyncThreads missing symbols (refactor API)
Minor improvements
Add AsyncThread::run_once() and AsyncThread::stop() to the API
Auto loader will attempt to load plugins that don’t have a version in their name. Example: If ‘Plugin’ is supposed to be auto-loaded then if it finds “Plugin.mmplugin” it’ll try to load that file. If this fails then it will NOT keep searching.
Make sure you also download the new plugin library for 12.2. I found out the hard way when it started throwing header errors and would not load plugins.
I’m super interested in MIDI out. Especially being able to send continuous controller information. What is this rack interface that midi out works with? When I search online all I see is the Wi-Fi expander am I searching for the wrong term?
I’m really enjoying my meta module. I can’t wait till I can use it to send midi information on specific channels
There’s no module in VCV yet – so far the only way to add MIDI out is to add it from within the MetaModule (add a new module, select RackCore brand, select CV-MIDI module)
Eventually I’ll add support from within VCV – making a patch with the VCV builtin “CV->MIDI” module will automatically show up in the MetaModule
I think I would like to try the dev firmware you just released is there a guide to installing it I’m having a little trouble finding that part. I have downloaded the latest firmware and the latest plugins for version 2.0. I’m just fuzzy on how to transfer it to the hardware. Thank you for your patience Thank you for your patience
Great! Keep in mind that the “v2.0-dev” firmware are in-progress, developmental versions. So some features are incomplete, buggy, etc. It takes a little extra work to stay on top of these bleeding-edge releases (keeping plugins updated, not always good documentation, dealing with bugs and general weirdness…), but you get to use new features earlier.
I see - so I could send midi out from a CV parameters, but not necessarily the current value of a knob then? Unless I map the knob to a fixed voltage source and then sent that out haha
