Fix some differences in default value for AltParams when adding a module in VCV vs. MM: PR#390
Duplicating a patch over an existing open (unmodified) patch file works now PR#391
Re-opening a loaded patch file that was on a disk that you ejected/re-inserted, will now force the file to be reloaded from disk (in case you made changes) PR#391
Also merged in some wifi expander features, which I realize is not relevant until these are publicly available (estimated end of Oct/early Nov). But the work is done, and credit is due:
Excellent update. When updating the firmware, don’t be a dumb*** like me. I put both the new firmware and the new 1.3 module updates on the SD card at the same time. I started up the MM and it locked up trying to auto-load the old versions of the modules. I took the card out, put the old 1.2 versions of the modules on the card, started up the MM successfully, and updated the firmware. Shut down the MM, put the new 1.3 modules on the card, re-started the MM and all was (very) well>
I experienced the same but a solution is to first power up the MM without the sd card so it does not search plugins and after that insert the card and proceed as usual.
Oh and first of all:
Hello to everyone and a big thank you to 4ms and everyone who is involved giving us the wonderful MM. And also to everyone who contributes with ideas, suggestions etc to make it even better.
Cheers !
Sorry for the bug in firmware v1.2 that froze when it found a v1.3 plugin. What should have happened was the auto-loader should have skipped the v1.3 plugins until firmware v1.3 was fully installed.
In general, the best practice is to update the firmware first. Then update the plugins.
I recently wrote a little section in the docs about versioning:
I inserted new Firmware and plugins into MicroSD card but I could not even get the MM to load into the landing page. I’m stuck as it says “no Nano modules found…” @danngreen help.
Edit: leaving this here for those who encountered the same. Remove microSD card and boot. This will allow you to enter into settings page to update the firmware (which goes first) and then the plugins.
On hindsight, if auto loading of most recent patch does not work, the device should skip the process and go into landing page (boot screen).
