Is this correct? I cannot save any patch that uses a plugin, reloading the patch only loads the built in plugins included. Even if I manually load the plugins first (which is also a huge issue).
I have found that I needed to reload the patch with the plugins to get it to work. Autoloading existing plugins for a patch would be nice, the manually loading every time i power on is a pain.
You can set plugins to autoload.
Aah, that’s in the manual, guess i should have looked harder. Honestly this thing is so easy to use i didnt look at the manual… ![]()
