Ive quite a few ideas for modules but they often revolve around getting assess to data file (read/write) and also more complex displays.
I know this was talked about… but I wondered if there was any kind of roadmap / priority for these? in particular:
- direct draw api
- read/write access to data files e.g. samples but not limited to.
ofc, I recognise its a new product, so you have lots of bugs/feature requests from users all requiring dev resources - very important to get these right.
however, I think the above for (some) developers are pretty important, and would be good to try to encourage devs ‘whilst the iron is hot’.
I for one am still excited by MM possibilities, but we have so many other projects… so will tend to just naturally ‘move on’ to others , if I cannot do what I envisage. and unfortunately, time goes by , and you just never comeback.
put another way, I think the success of vcv is the way it allows community devs to build stuff that dream of… and I think this can help push MM too.
(also ofc, some porting efforts are, id say, are likely ‘on ice’ due to the lack of the above)
edit:
idea : module full screen mode.
another thought I had (not very developed, partly as direct draw is required fist)
for custom ui’s on module it will probably be useful to have access to the encoder (turn/push) directly… perhaps a way to really ‘focus’ on the module , make it full screen and navigation via encoder. or even perhaps ‘suspending’ the mapping of pots.
this may seem ‘counter intuitive’ … and certainly not the way vcv generally works.
but, it could allow devs to create MM specific modules that have (more complex) UIs with a more ‘direct’ control.
e.g. imagine creating an oscilloscope/spectrum analyser module.
a user could be fully focused on that one module full screen,… and then pots/encoders would control its functions…without having to do any mapping etc… just use fixed controls.
this make no sense on a desktop, but ‘focus’ on something like the MM with its screen size etc, I think makes a lot of sense.
