Euclidean box (techno)
I made this patch with the Wonderfull Rebel Technology modules.
-You can connect the Teenage engineering PO clocked (I have the Tonic)
-PO. CV-3 → to clock PO
-Audio 3 ← from PO.
Have FUN.
Oh by the way, in the yml file is the FM synth better tuned than the VCV version.
I will ask to Dan why there is a tuning difference in the file. Have fun.
Submit-Techno-Rebel-tech.yml (13.9 KB)
Submit-Techno-Rebel-tech.vcv (3.1 KB)
Hey, thanks for sharing your patch. I just tried it but unfortunately it crashes after 1-2 sec, saying:
Audio stopped: patch load > 99%
I’m on the latest firmware v1.4.2 and only loaded the required plugins.
Any idea?
Edit:
I managed to run it! I only activated autoload for the plugins and reloaded the patch after a power cycle. It uses about 90% capacity.
First impression, it sounds awesome! Even without additional external drums.
Try increasing the block size at 48 kHz, or lowering the sample rate to 32 kHz.
Ok, will try next time if problems arise. It is running at the moment (see above). Thanks a lot!
What is the y knob doing, mapped to switch the sequence mode of the second Stoicheia? It’s called ‘Melody alt’ but I can’t spot any changes in either the klicks or the FM voices.
Hey DeepSea,
this patch is running on 48/512 and the Melody alt is connected to the Stoicheia for alternating the sequence. Have fun.
are you posting the yml for this patch?
The download is in the first post…
