Elastika Metal Resonance
-Main audio outputs on channel 1 and 2
-A VCO’s four main wave shapes are ran into a scanner which allows the user to crossfade between different wave shapes.
-The output of the crossfader goes into a shaped dual envelope VCA where a simple decay envelope is applied.
-The patch then runs into an Elastika Sapphire, where modal synthesis is applied.
-The output of the sapphire is ran through a dry/wet with the output of the VCO.
-The output of the crossfader then runs into a Mid/Side encoder/decoder to manipulate the stereo field.
-The output of the Mid/Side is fed into a valley plateau reverb
-The entire patch then goes through a limiter for volume protection.
-Two triangle wave LFOs are cross modulated with one another and are processed by a sample and hold (LFO1 = clock, LFO2 = sample).
-Before LFO2 hits the sample and hold it is crossfed with white noise to allow random deviations of voltage to be sampled.
-The output of the S&H is used to control the pitch of VCO as well as scramble all of the parameters on the Elastika Sapphire.
MetaModule knob mappings:
A - LFO1 Frequency (clock)
B - LFO2 Frequency (sample)
C - LFO1 CV attenuverter
D - LFO2 CV attenuverter
E - Triangle/white noise crossfader for sample and hold
F - VCO main frequency
U - VCO attenuverter
V - Waveshape: crossfader for main waveshapes of VCO.
W - Decay time for main VCO pitch
X - Dry/Wet for Elastika.
Y - Reverb Dry/Wet
Z - Reverb decay time.
Lastiksteppa.vcv (4.0 KB)
Lastiksteppa.yml (14.0 KB)
The files for this post have been updated so that they automatically select the recommended sample rate and block size for this patch of 32k/512. Enjoy! :smiley:
I love this patch, thank you!
