@danngreen, I realized as I was verifying my modules between the MM and VCV that Eightfold doesn’t show up in the brand list, but if I search by function I can find Orca’s Heart V2 that way. Thought you should know. I am loaded up with both the current firmware and libraries.
Thanks for catching that and reporting it. The metadata for that plugin had a blank brand name. The module is present and will work in all patches, but as you found, you can only access it from the Add Module page if you sort by tags. I fixed it, and will push a new firmware version.
