Edit2: As Ross suggested below, selecting audio driver fixes the issue.
Edit 2: Workaround if anyone runs into the same issue, select all modules, copy, delete and paste. Now you can save through the metadata
I can make my own patches, map knobs and export them from vcv rack. However when I download a patch from the gallery and try to make changes , the save button on the meta module (inside of vcv) does not work. Has anyone encountered this same issue? Everything is up to date, and I’ve tried editing and saving on two different computers.
I’ve also deleted and readded the meta module but no dice still.
Edit: It seems to happen to some patches, but not all, I cannot figure out which ones but I suspect maybe the bigger ones can’t be edited.
