Dual Looping Delay Sound on Sound Looping Patch
You can watch the video for this patch on YouTube here.
FOR THIS PATCH TO PLAY THE ONBOARD WAV FILE, YOU MUST DOWNLOAD THE AUDIO FILE AT THIS LINK AND PUT IT IN THE SAME DIRECTORY AS YOUR PATCH FILE
External Audio Routing:
-Main outputs on channels 1 and 2
-External audio input on channel 1
Internal Audio Routing:
-A Basic Wav Player is fed into the normal input of external audio so that you can play onboard sounds. This is then fed into both channels of a DLD
-The outputs of DLD are fed into a stereo chorus and a stereo crossfader for a Dry/Wet mix
-The outputs of the chorus are fed into the other side of a stereo crossfader for a Dry/Wet mix
-White noise is fed into a bandpass filter and sent to the stereo inputs of a stereo crossfader
-The output of the chorus is fed into the other stereo inputs of the stereo crossfader for a balance control between the program material and noise
-The output of the crossfader is fed into a distortion
-The output of the distortion is fed into a DJ filter for timbral control
-The output of the DJ filter is fed into a Stereo Width module to control the stereo width of both loops
-The output of the Stereo Width module is fed into a plate reverb.
MetaModule knob mapping:
A - Loop A dry/wet
B - Loop B dry/wet
C - Tape hiss
D - Drive
E - Filter cutoff
F - Fitler resonance
U - Chorus dry/wet
V - Chorus speed
W - Chorus depth
X - Stereo width
Y - Reverb dry/wet
Z - Reverb size
Button 1 - Record A
Button 2 - Clear A
Button 3 - Reverse A
Button 4 - Record B
Button 5 - Clear B
Button 6 - Reverse B
Button 7 - Basic WAV Player loop on/off
Button 8 - Basic WAV Player play
DLD Sound on Sound Looping.vcv (3.6 KB)
DLD Sound on Sound Looping.yml (14.7 KB)
Download harp.wav here: (click 3 dots)
I don’t see the option to download that harp file on Soundcloud.
The download link appears in different places depending on whether you’re using SoundCloud in a browser or mobile app, but it is there! (It may have been enabled after the time of your post.)
For some weird reason I cannot get the patch to work with external audio, do I need the button expander for this to work?
You can edit the patch to remap those functions to something other than the button expander (MM knobs, MIDI controller, etc.).
