fairly chill sine chord generator. can produce both more accessible drones and or also weirder experimental stuff. fun to play with the octaves (UVW) and add fm’y textures with the Y knob. with octaves all set low and Y knob up a bit, you can also get some rattly pulses for potentially more rhythmic type sounds. uses about 43%
A-C = volume for sine tones 1-3
D-F = octave for sine tones 1-3
UVW = notes for tones 1-3
X = master volume stage
Y = texture grit
Z = verb wet dry
DrooonGen1.yml (10.3 KB)
DrooonGen1.vcv (2.6 KB)
---- alt version demonstrating the rhythmic type stuff this can do (same patch, different initial knob config)
DrooonGen1-lowRhythmic.yml (10.3 KB)
DrooonGen1-lowRhytmic.vcv (2.6 KB)
