DLD channel A problems
So I’ve created a patch and part of it is using the 4ms DLD and I’m noticing that Channel A is just passing the audio through, but the delay is not functioning. I can change the divisions and put the 3 way switch in any position and nothing. The virtual LED for that channel is just stuck on no matter what. I’ve tried deleting the DLD and putting it back, but the issue persists. However, one weird thing is that I created a new patch with only a DLD to test it out and A channel works as expected in that patch.
So, it’s kinda confusing. Not sure what is causing the issue.
Anyone else having this issue?
Thanks!
Oh, not sure if useful, but figured I’d add that I remember having this problem with channel B on an earlier firmware, but it got fixed. Now I’m having the same problem with channel A. Not sure if it’s a similar fix or something totally different. Just thought I’d mention it.
There’s another thread where I mentioned this, but in case anyone comes here by searching: this issue is fixed as of firmware v1.6.6
