Remix is freezing in the cpu load tests, @etcetc do you see any potential issues with the code in that module? I haven’t had a chance to put a debugger on it (preparing for Superbooth).
I just tested it again on 2.0.2 with an attempted fix, I can add remix and delete it now without crashing, but not sure if the delete crash was a separate firmware bug that got fixed. Could you try the latest tagged release 2.0.1 now?
Also, I’m going to merge the cpu test routines into the main branch so that anyone can run it and test out their plugin before releasing it.
I think I’ll make it a requirement for entry into the Module Finder to pass the CPU test (this is how we generate the CPU numbers there, so it’s bound to come up).
Here’s my first test release for that, feel free to try it out any of your ports:
