https://metamodule.info/plugins
In the main list of plugins, it would be great if plugins that were updated or added could have the date of change on the title next to the name. That way we can see from the overview if anything new was added/changed. If you can only add in the details section, give us an expand all button to open all details so we don’t have to open one at a time to look for changes.
I also noticed the version posted on the website doesn’t display on the actual file details on MacOS. When I check my vst/au plugins, the version number shows in the file details so I can always check if I have the most recent version. Can the version details be added to file meta data?
this would be useful! i am currently just .rar’ing them and inserting the version number there. a bit more work, but has me set for now:
My assumption is that none of the external (not built-in) plugins have received any updates since the MM live date (Aug 27). Is that correct?
I agree there needs to be some visual indication in the Plugins section when updates are published, and perhaps an entry made in the Announcements section when existing plugin sets have been updated or new plugins added. I know that the 4ms folks (especially Dan) have been very busy working on the firmware and plugin updates, but there was nothing in the announcement section about the recent firmware update. I wonder how many MM owners are not aware of that update.
We’ve put out a few versions of the plugins maintained by 4ms. You can see all the releases here:
Most of the changes are just us tweaking the metadata in the plugins, or adding new plugins (RebelTech, VCV Fundamental), but some notable releases were v1.0.12 which fixed the artwork on the VCV VCF module and added the CountModula 12x16 Gate Sequencer.
Yeah, we’ll try to make announcements when a plugin is updated. We’re getting better at it!
We’re figuring out how to display the version on the site right now. It’s a bit confusing since there is a VCV Rack version, MM plugin version, and an SDK/API version (which is tied to the firmware version). But I think we have a plan to just display the MM plugin version next to the download link.
And then the actual .mmplugin files will have the version in the file name:
Bogaudio-v1.0.16.mmplugin for example.
Support for multiple versions of plugins has been merged into the main firmware branch, and will be present in the next firmware release. At the same time, we’ll start adding the version number to plugin filenames.
