CV > MIDI module behaves differently depending on how patch was created
I know we can’t yet set MIDI channels in the CV > MIDI module in VCV Rack, but this is another level of complexity:
  • When I create a patch on the MM, then create a CV > MIDI module within that patch, the CV > MIDI module has an Options menu with the MIDI Channel, Pitch Bend Range, and other settings.
  • But when I create a patch in VCV, send it to the MM, and then add a CV > MIDI module on the MM, the Options menu is not there!
It is weird for patches to behave differently on the MM depending on where they originated!
