Custom plugins folder
Id really love to be able to specify (or even hardcode) a custom/user plugin folder that is separate from ‘supplied’ metamodule-plugins folder.
basically, MM would load plugins from both folders.
(custom folder takes preference if there is a clash)
issue :
so now, MM has so many plugins - I’d guess we are all have the same update procedure
a) download new firmware and all_plugins.
b) delete firmware and plugin folders, to ensure ‘clean’ MM
c) unzip, drag over folders from download
d) boot mm, update firmware
note: I cannot just ‘overwrite’ in (b), as version number of plugin file may change, so you’d have stale files.
step (b) means I lose anything that is not released in all_plugins.
use-case / my issue
I have various ‘custom plugins’, that aren’t in all_plugins, and likely never will be.
step (b), means I have to copy them across again.tbc, its not a huge issue… just an extra step.
But also, I’d prefer if these plugins were in a separate folder anyway, for organisation etc.
as, I kind of view ‘all-plugins’ as factory/supported modules, not strictly true but you can see where Im coming from.
Im sure its not a feature many will use…
I see 3 possible use-cases
  • users testing beta / test versions of plugins
  • plugins that are ‘released’ outside of all_plugins for whatever reason ( * )
  • devs :slight_smile:
( * ) I could see my Erae plugin being released as simple github download, simply because 99% of users have zero use for it, as they don’t own Erae hardware :wink:
There’s an undocumented feature that you can put .mmplugin files in the root directory of the SD card or USB drive, and it’ll find them. Not as clean as using a custom folder, but it works already.
I can add a second dir to scan, too. Maybe mm-plugins/?
There’s already a triaging that happens since it can find multiple copies of a plugin on an SD card and on a USB drive, so it checks versions and sorts newest->oldest. Having another dir to scan would fit right into this.
oh, thats cool…
Im ok, with root directory., but yeah 2nd one might be cleaner.
Id probably go for something quite obvious for a name mm-plugins, I think for new users would be confusing… do I use mm-plugins or plugins, they might think they are synonymous.
perhaps user-plugins?
some users, might be familiar that computers, have user and system directories for things like libs, plugins etc.
he ‘overriding’ nature is not obvious, but also not totally unfamiliar.
I just pushed a change to scan “user-plugins/” as well as the root dir and “metamodule-plugns/”.
Also merged in the console features. It’ll all be in v2.3.1
