My patch is showing 91-92%. Sometimes when I adjust a parameter (I’m seeing this mostly in the Clouds clone) the audio shuts off with the overload error. I can restart audio, and it’ll play fine till I make some more adjustments. I’m not changing the actual patching, only turning knobs.
Not sure if this is an actual bug or only likely behavior when you get close to maxing out the CPU.
I can come back later and attach the .yml if that’s helpful
i feel you! i was getting this with 4 cvds(which is known to be real cpu lite modle), when multi mapping a single mm knob to the 4 time knobs on the cvds. my patch was running about 70-80 and would get the overload/audio stop so i just removed those mappings altogether. although i haven’t tried again with the new 1.3 plugins, hope there’s been an improvement there.
i read in another post that dan is considering giving us the option to remove overload protection and just have audio glitches/underruns occur. hopefully we can have that option as i think the occasional glitch during a live set would be far far better just having the patch/audio completely stop.
