Hey Dan. Would you mind checking over this patch for CPU (over)usage?
LV-426 v2.yml (12.2 KB)
It’s not that complex, but I’m only able to get it to run at 24 kHz. Could it be the MIX8 that’s hogging the CPU?
Thanks.
Thanks.
Well, the according the CPU load speadsheet, Mix8 can use up to 58% of CPU with all jacks patched. Around 2/3 are patched in this patch, so this is probably the heaviest CPU user of the modules. Try replacing that with multiple mixers (4ms StMix is very light-weight).
The PonyVCOs are next highest usage, since you’re not using the Timbre or waveshape modulation, you could probably use something lighter – though I do see you using the VCAs, so might be a wash if you trade them out for 2x VCOs and a dual VCA. Worth trying though.
Thanks, that’s helpful.
