Control mapping, remapping etc suggestions
A few things that might be nice
VCV MetaModule:
cut-and-paste individual mappings from one control to another
cut-and-paste sets of mappings from one knob set to another
swap mappings (ie between two controls)
remove the Alias at the same time as Unmapping a control
set ‘initialisation value’ of a control (for when patch loads) the same way as min/max value
move Alias text of w and x out of coloured rings around A and F
match value range (0-1) to hardware (0%-100%)
Hardware Metamodule
set curve on a control (log/lin/S)
assign controls to be attenuverters on inputs/outputs
alternate displayed units for control values
alternate control type display (button, 2-way, 3-way switch etc) for controls
patch ‘presets’ resetting controls to specific values
‘auto use’ option when moving from one knob set to another
Cheers.
Was thinking about something else last night; Ive found myself putting the same controls (eg filter cutoff) on multiple knob sets so there’s no interruption going back to a different knob set when I want to tweak them.
Would be pretty helpful for that to either
have some mark controls as ‘locked’ and not change with the knob set,
or alternately
have some sort of ‘split’ to knob sets. Im thinking that maybe an option to swap A-F separately from u-z?
+1 to setting your own curves. would be great if we could also import our own. sunvox’s curve system cones to mind:
https://warmplace.ru/forum/viewtopic.php?t=4400
also +1 to mapping knobs to input (or physical inputs to virt knobs/buttons)
