Comprehension questions from a beginner
Essentially, the 4ms Meta won’t have the cpu horsepower to do all this with equivalent modules, nor does it currently have enough buttons to program a drum sequence using hardware. this latter point may change as new modules are released. However in the interim I suggest loading this patch into VCV rack: Quick Drum A - Sonic Mayhem Abounds as this relatively simple drum machine set up pushes the Meta close to its cpu limits and ought to give you an idea what is possible right now on the hardware. Alternatively dig through the other vcv patches uploaded here to get an idea of what people are building using the Meta.
