You probably couldn’t achieve the same level of finesse with 14bit MIDI. With small knobs, 14bit is not that big of an increase in fine control.
Hmm, you could possibly achieve this by using min/max values for a control? Let’s say I throttle the midi cc to only span 10% of the control – this means the MIDI CC has more ’resolution’ available for that 10% span.
